my car cuts off somtimes when going from park to D..??
Old 05-15-2007, 01:17 AM
tp65
tp65's Avatar
Default my car cuts off somtimes when going from park to D..??
what could cause my car to stall or shut off when I take it out of park and put it in reverse and then put it in drive and sometimes it stalles....
tp65 is offline
Old 05-15-2007, 01:26 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: my car cuts off somtimes when going from park to D..??
dirty maf wires, bad iac, those two working together with an idle that is too low or causing a low idle
luckythirteen13 is offline
Old 05-15-2007, 01:41 AM
tp65
tp65's Avatar
thanks
tp65 is offline
Old 05-15-2007, 01:45 AM
luckythirteen13
make sure the tps is set correctly too. might as well eliminate it as a problem
Old 05-15-2007, 01:52 AM
decipha
decipha's Avatar
could also be a vac leak.. chek your vac lines
decipha is offline
Old 05-15-2007, 02:45 AM
All4n
All4n's Avatar
lucky, what is IAC and how do you set TPS?
All4n is offline
Old 05-15-2007, 05:00 AM
Blckstng93
Blckstng93's Avatar
I had stalling going from P to R. Ended up being a bad MAF.
To test the TPS pierce the green and black wires (i think). Preferred setting is .98-.99v. Use a digital voltmeter.
The stock TPS can be made adjustable by enlarging the holes a little. Do that, rotate the TPS while checking the voltage. Once its reading good tighten it down but dont overdo it, the TPS will crack eventually.
Even ifa stockTPS reads ok, its always nice to have it adjustable. The IAC is that silver thing on the side of the throttle body. Careful with the gasket if its never been off, sometimes they stick.
Blckstng93 is offline
Old 07-21-2007, 08:53 AM
FatKat
FatKat's Avatar
It maybe the Mass Air Flow Sensor.
FatKat is offline
Old 07-22-2007, 03:00 AM
850SN95
850SN95's Avatar
i have the same problem and there is stang exactly like tp65's in Tallahassee,FL
850SN95 is offline
Old 07-22-2007, 03:45 AM
blackout
blackout's Avatar
it could be the torque converter slipping...
blackout is offline
djbigskrilla
09-20-2022 01:04 AM
kirk35
08-17-2015 08:42 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: my car cuts off somtimes when going from park to D..??
