Replacing the Clutch Pedal Assembly
Old 05-30-2007, 07:06 PM
ThrashN
ThrashN's Avatar
Default RE: Replacing the Clutch Pedal Assembly
Make life a bit easier on yourself and take out the seat. You can also remove the steering colum.
ThrashN is offline
Old 05-30-2007, 08:13 PM
94gtcoupe
94gtcoupe's Avatar
so it works fine after u drive a few miles??? do u warm up the car at all b4 i drive or do u just start it up let it idle for like 30 sec. then go? sounds like a lubrication problem in the tranny to be, check the fluid level and the smell of it too
94gtcoupe is offline
Old 05-30-2007, 08:46 PM
Swirl
Swirl's Avatar
ORIGINAL: 94gtcoupe
I usually just go! - :P (to used to an automatic in my DD)
I figure I should check the fluid and replace it if need be while I am doing all of this.
The main reason for replacing the clutch pedal assembly is due to the previous owners stupidity. There is way to much play in the pedal with the current one.
Hopefully I can get this done this week. If I get too annoyed I will take out the seat and the entire steering column.
Swirl is offline
Old 05-31-2007, 12:08 AM
Swirl
Swirl's Avatar
Here is the next problems that I have run into.
I have attached the images to the post.
[IMG]local://upfiles/50859/05B9B882D5AF4029AF0150CBB0752459.jpg[/IMG]
[IMG]local://upfiles/50859/A79C78BB619C415091CDA8CF3DFE13E9.jpg[/IMG]
[IMG]local://upfiles/50859/A0B98147382D49F38D432EAC371BEFCA.jpg[/IMG]
[IMG]local://upfiles/50859/CFADB5AC7D4244C298DFAE818D4C46A1.jpg[/IMG]
[IMG]local://upfiles/50859/FE0E3F90A8E64B2EB5106AA70B212E6C.jpg[/IMG]
Swirl is offline
Old 05-31-2007, 12:09 AM
Swirl
Swirl's Avatar
And one more!
[IMG]local://upfiles/50859/93ECED9D689C43A7825F4C7D057302CC.jpg[/IMG]
I really don't know what to do at this point.
If anyone lives in the Northern VA andis willing to help me out, that would be great.
I'll buy some beer, or pay you to help me finish this!
Swirl is offline
Old 05-31-2007, 05:01 PM
Swirl
Swirl's Avatar
Any ideas on why that bar is there (a brace maybe?)
Swirl is offline
Old 05-31-2007, 08:06 PM
94gtcoupe
94gtcoupe's Avatar
i highly suggest taking the seat out even if your not anoyed yet, makes things a ton easier and only takes 5 min. to do... any thing i do under the dash the seat comes out EVERY time even if its not my car
Old 05-31-2007, 08:39 PM
945LSTANG
945LSTANG's Avatar
remove the seat and you will be able to rip everything out easier. I took out my seat when i put in my new clutch linkage. The install went buy so much faster once the seat came out. There are only 4 bolts holding the seat in. Its so easy to do and it will make ur life so much easier under the dash.
945LSTANG is offline
Old 05-31-2007, 10:09 PM
Swirl
Swirl's Avatar
Looks like the seat is coming out! - :P
Any idea on that extra bar welded to the assembly?
Swirl is offline
Old 05-31-2007, 10:18 PM
945LSTANG
945LSTANG's Avatar
i have no idea y the bar is there. ive never seen that before
Quick Reply: Replacing the Clutch Pedal Assembly
