Replacing the Clutch Pedal Assembly
#61
RE: Replacing the Clutch Pedal Assembly
I finally got it back together! -
I started to drive it, but the pedal is catching really high?
Quick question:
Which way to I need to adjust the cable to make it catch it lower?
Quick question:
#63
ORIGINAL: 945LSTANG
to u mean that its to tight or not tight enough? too tight = clockwise too loose = counter - clockwise
I am assuming that I need to tighten it, so that it engages the clutch lower on the pedal.
#65
Ok well I can finally drive the Mustang again! -
I have a few issues though. I think I need to tighten the cable jsut alittle bit, it seems to loose (easy enough to do). I can also hear a clicking noise when I push in the pedal (maybe a wire is stuck behind it). It also feels like the cable has a rachet feel to it when I push the pedal, is this normal with an adjustable cable and doubl hook quadrant?
My brake lights don't work either - :P I figure I missed a wire to hook up. Does anybody happen to have a picture of what thiers looks like under the dash around the brake pedal?
Thanks for all the help.
#67
ORIGINAL: mattdel
the brake light switch has 2 wires, usually the same color, hooked up the a plunger style button that sits right around the top/middle of the pedal assembly.
Thanks! I will try to hook those up tonight, don't need a ticket - :P
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
