why low HP? and top end opinions
Old 06-13-2007, 02:21 AM
  #21
Mustangkiler
Mustangkiler's Avatar
Default RE: why low HP? and top end opinions
yes you need new headers, cant run afr 185s without some piston work and good set of heads alone could get you 40 hp
Mustangkiler is offline
Old 06-13-2007, 02:34 AM
  #22
nacanitihs
nacanitihs's Avatar
you could always get some 1.6 or 1.7 roller rockers if you cant afford to buy heads
or get these like adder said http://www.tristatecylinderhead.com/...products_id=40
nacanitihs is offline
Old 06-13-2007, 02:41 AM
  #23
LCBlackDep183
LCBlackDep183's Avatar
im sorry, I have to say those numbers are low, ive seen stock foxs and sn-95s lay down more power than that. only thing I can immagine is that your car is running horrible, which could happen if you popped that cam in wrong, or your car is simply running WAY too rich.
BTW you did set your timing correct?
LCBlackDep183 is offline
Old 06-15-2007, 01:32 AM
  #24
droptopfoxgt
droptopfoxgt's Avatar
i have my dyno sheets at home and im pretty sure they have a/f ation on them. i didnt put in the cam or set the timing, performance specialties did. when it was dynoed it was also on a motis scanner and nothing was out of the ordinary except the fuel pump which was replaced and then it was all good. tomorow i will check my a/f numbers
droptopfoxgt is offline
musnicki
09-23-2015 07:11 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: why low HP? and top end opinions
