Will f303 cam work with 1.7 r.r.??
RE: Will f303 cam work with 1.7 r.r.??
let me just put it this way. ive seen it tried before and it diddent work now an e cam with 1.7 rockers will clear it has 220 duration at .050. a b cam will work also i have one now in my car and it sux dont waist money on that one. if it was me i would use a tf cam with 1.6 rockers regardless beacuse their designed using the tftw heads
With my first hand experence, it will work. Me and my bro-in-law just put that set up in his car (f-cam 1.7s) he has a 93 coupe. The only problem is that the stock valve springs seem a bit weak at higher rpms.
ORIGINAL: SuperFox88
[align=left]It will not work. My friend wouldnt listen to us and he put an F cam in with 1.7 and broke valves cause they were hitting the pistons. You can only go up to I think .520 lift with stock bottom ends.
[/align][align=center][/align]
ORIGINAL: 15austin
The duration doesn't matter as much as you guys think. Its the overlap that matters. If the valve is opening as the piston is coming up then your gonna smack the valve.
The only way to really know if its gonna work is degree the cam, check proper pushrod length and rocker geometry then check piston to valve clearance. I think its .080 clearance on the intake side at minimum and .1 on the exhaust.
09-01-2015 08:16 PM
