ford ltd cop car 5.0?
Old 06-12-2007, 10:57 PM
Joel5.0
Joel5.0's Avatar
Default RE: ford ltd cop car 5.0?
All you have to do, if a HR cam is that important, is to install a set of linked HR lifters with the appropriate HR cam, and you have a HR cam setup. The lifters are expensive though......when compared to the OEM ones for a roller ready block.
Joel5.0 is offline
Old 06-12-2007, 11:09 PM
86 5.0L
86 5.0L's Avatar
^exactly or get a flat tappent cam, they can make some good power also
86 5.0L is offline
Old 06-13-2007, 05:12 AM
subhumantat
subhumantat's Avatar
ttt
subhumantat is offline
Old 06-13-2007, 06:56 PM
subhumantat
ttt...anyother ideas, specs, or thoughts?
Old 08-06-2007, 10:28 AM
Mike14
Mike14's Avatar
could you just find a carburated crate motor to be put in there? would everything bolt right up and run?
Mike14 is offline
Old 08-06-2007, 10:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
The 85 cfi mustang was RATED AT 180 hp and was A H.O. motor in it's class vs other cfi ford 5.0 v-8 cars..although it wasn't much of a h.o in my opinion it did have tubular headers a dual snorkal air cleaner and a differnet flat tappet cam vs the standard cfi motors that came in other cars like ltd's that some of which were non-h.o motors all in all I junked my cfi set up in favor of a late model roller cam engine. with 4 barrel!! to give you an idea of the crappiness of cfi I modded the engine and removed the aod in favor of a t-5 and with a performer cam 448/472, roller rockers, true dual exhaust, ported e7te heads and 3.73 gears the car with the stock cfi fuel injection ran a best of 15.4 with slicks... the only change I made after that was convert it to a 4 barrel with intake and carb and I ran a 13.47 at 99 mph
mjr46 is offline
Old 08-06-2007, 02:12 PM
85GTsleeper
85GTsleeper's Avatar
ORIGINAL: ZachW04Stang
All the aod 5.0 mustangs had cfi pre 1986. They are dog motors, the most hp they had was in 1985 and it was around 180 I think. The motor may not be a ho, so it won't even except rollor lifters. You'd probably be better off buying a motor out of a 87-93 mustang.
or an 85 gt motor seeing they had HR and all forged internals if he wants to go the carb way
85GTsleeper is offline
NorthAmericanTuning
03-18-2016 11:21 AM
MusBBad95
08-17-2015 09:39 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
05slpGT
08-12-2015 02:32 PM
Quick Reply: ford ltd cop car 5.0?
