T-5 Tranny Question
Old 06-16-2007, 11:44 PM
stanmiller3569
stanmiller3569's Avatar
Default T-5 Tranny Question
I have a 92 5.0 w/T-5 that is causing me problems. I have read posts about throwout mbearings making a squeaking noise at idle w/ clutch all the way out then stopping when a little pressure is applied. Mine is doing that but it is also making a kind of grinding noise 1st thru 3rd. Once I hit 4th, it stops the noise. Would the throwout bearing be causing this also?
stanmiller3569 is offline
Old 06-17-2007, 12:20 AM
dimebag
dimebag's Avatar
Default RE: T-5 Tranny Question
how is the clutch adjustment? and how is the trans fluid level? i havea feeling either ur clutch needs adjusted, or ur syncro's are shot
dimebag is offline
Old 06-17-2007, 12:22 AM
stanmiller3569
I just topped the fluid off this afternoon. Not quite half a quart low.
Old 06-17-2007, 12:30 AM
1BADASSLX
1BADASSLX's Avatar
do you still have the old clutch qwad??
1BADASSLX is offline
Old 06-17-2007, 12:35 AM
stanmiller3569
No. The guy that I bought the car from had already put an aftermarket quad on. If it is the syncros, what kind of price am I looking at to have it repaired? Any ideas?
Old 06-17-2007, 12:38 AM
dimebag
dimebag's Avatar
it sounds to me like its ur syncros- matter of fact, only way i would tell u anything diff is if iwere there to see it myself, so goin onwhat ur telling us, it is your syncros
n e way...
shop-~1000
BUT... pm 94gtcoupe, hes a good guy, knows alot about t5's, and rebuilds them for cheaper. i can honestly say if i needed that done, and didnt have the confidence to do it myself(personally ill do it myself, because im in school for automotive, and do EVERYTHING myself, but if i didnt...) id comfortably hand it over to him and trust him w. it
dimebag is offline
Old 06-17-2007, 12:41 AM
stanmiller3569
Ouch! Sure would like to spend a grand on something besides a repair. Oh well, gotta do whatcha gotta do I suppose.
Old 06-17-2007, 12:42 AM
1BADASSLX
1BADASSLX's Avatar
well the sqweeking aint your syncs but it cost me about 200.00 buckss to build mine but i did it my self and i work and run a power train shop here in ohio are you close buy?? the sqweeking you are hearing is the pivot ball in your bell houseing that the clucth fork rides on they get realy dry from clucth dust, a great mod for that is to drill a hole and put a grease zerk for that,, thats a old school 50 trick but ya look me up man if you live in ohio or close that you can ship to me call me 1-800-999-0228 mon-fri 8-5 ask for randy will fix you up!!!
Old 06-17-2007, 12:44 AM
stanmiller3569
Where at in Ohio? I'm in Lexington, KY.
Old 06-17-2007, 12:46 AM
1BADASSLX
1BADASSLX's Avatar
sweeeeeeeeet i have a store in lex its called power train its on nandino blvd you can take it there and the will shuttle it to me and you wont have to pay shipping!!!!
Quick Reply: T-5 Tranny Question
