F4TE heads...any good?
Old 06-17-2007, 02:39 AM
5.0stanger
5.0stanger's Avatar
Default F4TE heads...any good?
Are they better than the E7's? They are the stock head on a 95 351...I have a set and was thinking of swapping them on to my 5.0 if they are any good....or at least better than my E7's. I also have a set of 75 351 heads, would those be better?(I think they are D5AE heads...not sure)Thanks
5.0stanger is offline
Old 06-17-2007, 02:42 AM
VigCS
VigCS's Avatar
Default RE: F4TE heads...any good?
Are you sure? I pulled a roller 351w apart on a 97 truck and it had E7s on it.
VigCS is offline
Old 06-17-2007, 02:46 AM
5.0stanger
5.0stanger's Avatar
Those are the heads on the 94 thru 96 351's. I will have to double check, but I am pretty sure.
Old 06-17-2007, 05:47 AM
AdderMk2
Banned
AdderMk2's Avatar
F4TE are nothing more than an E7 head with larger head bolt holes.
you wanna fine some DOOE, F3ZE, or F77E heads
AdderMk2 is offline
Old 06-17-2007, 06:00 AM
w8less
w8less's Avatar
there is a set of 69 351 heads on ebay right now. these were on the corral
http://www.corral. net/forums/showthread.php?t=923240
w8less is offline
Old 06-17-2007, 11:45 AM
5.0stanger
5.0stanger's Avatar
So neither set are any good? I thought the older heads were like the 69 heads...same valves anyway.
Old 06-17-2007, 12:39 PM
my77stang
my77stang's Avatar
69/70 heads, i have the C9's on mine. that set for 500 bones from that link posted is a good price since they are already worked over and ready to be installed. ask if the guy had hard seats installed though, or you'll be adding lead substitute to your gas every time you fill up.
my77stang is offline
Old 06-17-2007, 11:30 PM
tinman
tinman's Avatar
That idea that you have to have the hardseats is myth.............
Lotsa folks wanted to dell us lotsa machine shop work back when but its myth now............
tinman is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
ctgreddy
09-20-2015 08:35 PM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: F4TE heads...any good?
