Power window relay....need help
Old 06-19-2007, 01:41 PM
50vertible
50vertible's Avatar
Default Power window relay....need help
I have a 92 mustang lx 5.0 convertible and im about to go out of my ^%$^ing mind trying to find the power window relay. ANY HELP would be greatly appricated.
thanks,
Noob
50vertible is offline
Old 06-19-2007, 01:44 PM
7upedition
7upedition's Avatar
Default RE: Power window relay....need help
are your power windows not working... which ones, on my vert the Drivers front was the only one working, replaced the other switches... no difference, replaced the one that works ... now they all work. Not sure where the relay is, sorry don't have the manual with me.
7upedition is offline
Old 06-19-2007, 06:14 PM
50vertible
50vertible's Avatar
The front two work fine, but the rear quarters won't roll up. Motors are fine, switches seem to work, I don't know what else it could be, if its not the relay. I really wish someone knew where it was. Called ford and the service advisor didn't even know what I was talking about.[:@] I just want my windows to roll up so i can drive my car again(been raining a lot).
Old 06-19-2007, 06:40 PM
7upedition
7upedition's Avatar
Have you tried putting 12V direct to the actuator for the rear quarter windows?
Old 06-19-2007, 07:21 PM
ttocs
ttocs's Avatar
ford uses a 5 wire system that does not use relays, the switches do all the work. With they system often if one of the wires becomes disconnected neither will work. Try cleaning your switch and checking all the contacts.
ttocs is offline
cr620
10-03-2022 10:18 PM
jwog666
12-27-2021 08:09 PM
jrrhd73must
10-02-2015 09:17 PM
09-25-2015 06:58 PM
Quick Reply: Power window relay....need help
