non HO to HO
Old 06-25-2007, 06:27 PM
shawnk007
shawnk007's Avatar
Default RE: non HO to HO
yes. but i dont know of anyone taking a non-ho block and trying to turn it into an HO engine.
shawnk007 is offline
Old 06-25-2007, 07:49 PM
F5GTS331
F5GTS331's Avatar
93 f 150= non hobut should still be roller motor that has the spider bracket and wishbones. to swap a cam remove your intake, valve covers, unbolt rocker arms, remove pushrods and lifrters, remove crank and water pump pulleys, harmonic balancer, timing cover, timing gear and chain, camshaft thrust plate, and your ready to pull out a camshaft. install reverse of removal. never hurts to replace lifters theyre about $110 bucks from summit racing.
F5GTS331 is offline
Old 06-25-2007, 07:51 PM
F5GTS331
F5GTS331's Avatar
oh and no matter what you do about lifters always submerge them in some motor oil
F5GTS331 is offline
Old 06-25-2007, 08:53 PM
mattylax12
mattylax12's Avatar
ok well i guess i will jsut wait to find an HO for sale thanks guys for the info
mattylax12 is offline
Old 06-25-2007, 09:00 PM
86 5.0L
86 5.0L's Avatar
the only difference in the non HO motor is the firing order and cam, if you were even planning on changing out the cam on a HO then you wont have any problems with the nonHO
86 5.0L is offline
Old 07-05-2007, 03:00 AM
franckybosnie
franckybosnie's Avatar
I got the same problem as you . I've checked on ford trucks forums and ask some guys and they were right. After 87 , every 302 (HO and non HO) has the same casting . That means that even a 302 non HO from a F150 is ready roller , even the 2 screws on the top of the engine for the spider , and it accept the roller lifters AND the dog bones .
To change the firing order , just swap your camshaft.
The pistons are different too . Non HO has flat top pistons , and the HO forged pistons , so if you stay with the truck pistons , you're gonna loose a little bit a compression (8.5 : 1)
swap all you got from your stang to this engine (cam , intake , water pump) and it will work well
franckybosnie is offline
Old 07-05-2007, 03:02 AM
franckybosnie
Oh yeah ...check this site .... it tell a lot about what your lookin at
http://www.geocities.com/cping3/late302.html
Hope that helped!
Old 07-05-2007, 05:41 AM
AdderMk2
Banned
AdderMk2's Avatar
Matt... I dont know if you'd be interested, but I have my 302 from my cobra chilling in my garage.. and I also have a 1971' 351w block at R&R machine shop on Clorane St off Sandy Lane...
lemma know... I need to get rid of one, or the other
*edit* BTW, i live in smithfield... about 10 miles north of you
AdderMk2 is offline
Old 07-05-2007, 09:06 AM
LTnone
LTnone's Avatar
Fortunately for you, the motor would already be out of the car. That makes the cam swap just that much easier. Are you going to keep it carbed? If not, you'll need a computer for a HO motor as well
LTnone is offline
