Wobbly Steering Wheel
Old 07-02-2007, 02:10 PM
Danegerous
Danegerous's Avatar
Default Wobbly Steering Wheel
When I'm hanging on for dear life, the steering wheel has about a 1/4" worth of wobble to either side. Before I start chopping things up, I wanted to see if anyone else has had a similar issue. Lemme know. And could you folks also recommend a nice replacement whell for an '87 gt? Thanks.
EDIT: actually, I just found this: https://mustangforums.com/m_2809749/tm.htm. So, I'll give that a shot and see what happens.
Danegerous is offline
Old 07-02-2007, 02:22 PM
Blckstng93
Blckstng93's Avatar
Default RE: Wobbly Steering Wheel
Check the mounts under the dash where the column mounts. Should be 2 bolts under there on the framework of the dash. If they are loose the column will move around some.
Blckstng93 is offline
Old 07-02-2007, 04:01 PM
raven_ghostwolf
raven_ghostwolf's Avatar
Do you have tilt wheel ? If so they start getting a little play in them over time. Only fix I know of is change to a non-tilt column or find a replacement column. I have a 87 non-tilt column if your interested out of my car when I put in a tilt column (andit wobbles just a little). Mine doesn't have the cruise control stuff though.
raven_ghostwolf is offline
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
Quick Reply: Wobbly Steering Wheel
