TPS bad?
Old 07-05-2007, 01:23 AM
93_five_oh
93_five_oh's Avatar
Default TPS bad?
i hooked my volt meter up to the tps today because i was going to set it to 1 v and to my astonishment it showed a reading of 5.02 v while the throttle body was closed.
i opened it and it still showed 5.02 v.
could it be that the tps is bad? if so, where can i get a new one and how much are they?
93_five_oh is offline
Old 07-05-2007, 01:35 AM
Joel5.0
Joel5.0's Avatar
Default RE: TPS bad?
Need to make sure you're probing the right wires (green and black color wires at the sensor side)....BTW....if you don't have any TPS related failure codes (23, 53, 63) showing up in a DIY KOEO/KOER/Cylinder Balance Self-Test you're not gaining anything in terms of performance or driveability......the computer is working within specs. Setting the TPS to .99998 vdc is a mythical setting "upgrade".....
Joel5.0 is offline
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no newbie it probably isn't bad most sensors have what they call a 5 volt reference feed that the computer works off of you'r probably probing the wrong wire you need to probe the signal wire out of the tps.
mjr46 is offline
Old 07-05-2007, 01:39 AM
93_five_oh
93_five_oh's Avatar
LMAO[:@]
yeah yeah... black and green. leave it to me to probe red and black.
sorry guys
Old 07-05-2007, 03:59 AM
HogWash94
HogWash94's Avatar
Incase it is bad here ya go.
http://www.latemodelrestoration.com/...s/memsen1.aspx
HogWash94 is offline
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: TPS bad?
