IDLE ISSUE!!!!!!!!!!!!!! HELP
Old 07-07-2007, 09:00 PM
ninconpoop31
ninconpoop31's Avatar
Default IDLE ISSUE!!!!!!!!!!!!!! HELP
hi everyone I have a huge idle issue... my 1994 mustang gt with a 5.0 v-8 idles around 1800 rpm in park but every other gear is fine. I have replaced my IAC valve, PCV valve, MAF sensor and even tried messing around with the idle screw and throttle body stop screw and none of these things have solved my problem... someone please help me with this. thankyou
ninconpoop31 is offline
Old 07-07-2007, 09:33 PM
droptopred
droptopred's Avatar
Default RE: IDLE ISSUE!!!!!!!!!!!!!! HELP
I have the same problem, im not sure if you tried this or not, But Try cleaning the IAC they have the directions on yahoo!
droptopred is offline
Old 07-07-2007, 09:49 PM
Joel5.0
Joel5.0's Avatar
DIY KOEO/KOER/Cylinder Balance Self-Test
Joel5.0 is offline
Old 07-07-2007, 10:37 PM
bacon57
bacon57's Avatar
It could be a bad Idle Air Control motor I'm not sure if that is exactly what it is called but it should be near your throttle body.
bacon57 is offline
Old 07-07-2007, 10:58 PM
dillon1340
dillon1340's Avatar
is there a check engine light? is it possible that the eec thinks the car is cold? maybe a bad ect sensor?
dillon1340 is offline
2007StangV6
01-28-2016 06:09 PM
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: IDLE ISSUE!!!!!!!!!!!!!! HELP
