speedo stopped working
Old 07-10-2007, 07:36 PM
90lxstang
90lxstang's Avatar
Default speedo stopped working
yep just like it says. the other day it started bouncing up and down(between 0mph and whatever it was supposed to be at) and finally today it just stopped working all together. Seems like an easy fix. any ideas on where to start? thanks a lot guys!
90lxstang is offline
Old 07-10-2007, 07:56 PM
Blckstng93
Blckstng93's Avatar
Default RE: speedo stopped working
Check both ends of the speedo cable and the speedo gear at the trans for wear. Remove the gauge cluster and check things out. A wobbly speedo is usually a binding/dirty cable. Theres a possibility it snapped inside if its not working at all. Anything is possible.
Blckstng93 is offline
Old 07-10-2007, 08:20 PM
90lxstang
90lxstang's Avatar
my dad just told me his '82 stang did that and he had to grease up the cable where it connects to the speedometer. does anyone know what kinda lube or whatever to use?
Old 07-10-2007, 09:47 PM
Kick_Ass2k1
Kick_Ass2k1's Avatar
id reccomend buying a new cable if you go through all the trouble of pulling out the speedo to lube it. It's 17 years old, might as well replace it anyways, right? Besides, it's only $15 at your local auto parts store. A new cable comes with the lube for it too.
Kick_Ass2k1 is offline
Old 07-10-2007, 10:48 PM
90lxstang
90lxstang's Avatar
the cable was actually replaced a year ago because my car overheated once and it melted through
djbigskrilla
09-20-2022 01:04 AM
67LimeCoupe
11-25-2015 08:55 PM
importsmasher
10-09-2015 04:42 PM
m4xx
09-01-2015 06:46 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: speedo stopped working
