HCI 99% Complete - Help with last line! *NEED HELP!*UPDATED**
Old 07-11-2007, 11:05 PM
  #31
blackout
blackout's Avatar
Default RE: HCI 99% Complete - Help with last line! *PLZ HELP!*
ORIGINAL: creekrat
Yea, switching wires around is not a good idea, it will not fix the problem. It may have just kicked over a few times but it will not run anywhere close to right! Fix the dist first thing! You are just wasting your time and efforts swapping wires around and crap like that. Use the rag method to get #1 up on compression like I said earlier. I like this method because you can do it by yourself, and it is easy and sure to get things exactly where you want it. Painless. In the time it took you to swap wires around you could have had it re- stabbed!
Thanks creekrat, I appreciate the help. That gives me a lot better peice of mind knowing that the car should run now!
I'm going to try it now! Since I switched from 19lb injectors to 24lb injectors is the car going to run like complete **** since I don't have a new MAF? Am I able to purchase a 94-95 MAF and put my massair meter in that and then have MAF calibrated by a local shop? How much should it cost for somebody to calibrate the MAF and what do they do to recalibrate it?
THANKS AGAIN GUYS!
blackout is offline
Old 07-12-2007, 09:39 AM
  #32
my77stang
my77stang's Avatar
wtf are you talking about? the ONLY reason jumping wires 180 deg around isnt a permanent solution for a dizzy thats stabbed 180 deg out is because when you go to do a tune up in 50,000 miles you'll forget that you had it that way.
*sighs*
my77stang is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
TCStangerv6
10-11-2015 05:57 PM
ChampInSD
10-02-2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: HCI 99% Complete - Help with last line! *NEED HELP!*UPDATED**
