rocker arm fell off
RE: rocker arm fell off
An TDC won't necessarily be right, you have to get the lifter when it is down. Roll the motor till the rocker arm you are looking at goes up then down, then when the one right next to it start going up is when you start setting lash and preload...get it??
ORIGINAL: MadMan@TheWheel
News flash folks if your lifters a bled down, you will need to back off a 1/4 turn to leave room for the lifter to load...yes? on a hydraulic lifter that is
ORIGINAL: OnyxCobra
man, hearing all this crap makes me happy i used pedestal mount...
ORIGINAL: 5.0stanger
Its all the same, just weather you use shims or not. Pedestals are more of a pain to get right.
ORIGINAL: OnyxCobra
and for the record, studs are 1,000 times better than pedestal mount for multiple reasons [8D]
