Brake Calipers, 93 rear disc caliper piston!
Old 07-13-2007, 06:56 AM
TwotoneVert
TwotoneVert's Avatar
Default Brake Calipers, 93 rear disc caliper piston!
Does anyone know if the caliper screws in or pushes in? I have tried both and not having much luck. I did get the piston to move slightly by turning it, but it will not go any further and I will not be able to fit the assembled caliper on the disc. My cheesy repair manaul does not address rear calipers, only fronts. Thanks guys.
TwotoneVert is offline
Old 07-13-2007, 06:58 AM
tmajikman
tmajikman's Avatar
Default RE: Brake Calipers, 93 rear disc caliper piston!
Do you know what vehicle they came off of. Do you have the special tool to turn the pistons back in?
tmajikman is offline
Old 07-13-2007, 07:20 AM
TwotoneVert
I am 99% sure they are Cobra calipers. And if they turn, I will need to get the tool. My repair manual states I have to push the fronts back in with a c-clamp, but I was not sure about the rears. They are not oem on my car.
Old 07-13-2007, 08:01 AM
5.0stanger
5.0stanger's Avatar
The rear require a special tool so you can push, then turn them in(if they are a ford caliper)
5.0stanger is offline
Old 07-13-2007, 09:29 AM
silver91gt
silver91gt's Avatar
if it has some slots in it then it will need to be turned( i use opened needle nose pliers) but if theres no slot then it is a push in one, take off the master cylinder cap to allow the fluid to raise when u press in the caliper
silver91gt is offline
Old 07-13-2007, 02:24 PM
TwotoneVert
Thanks guys.
Old 07-13-2007, 06:15 PM
black89gt
black89gt's Avatar
all i did was take a straight pry bar and turned it in where htey have the slot on the piston.
black89gt is offline
Tivo304
08-28-2023 12:19 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Brake Calipers, 93 rear disc caliper piston!
