HCI Finished - Car doesn't want to idle stalling out*Updated Pg2*
#24
RE: HCI Finished - Car doesn't want to idle stalling out
As long as we're asking all these question........ I thought I'd ask (and believe me I'm not trying trying to be a dick here) but did you double check to make sure thatthe dot cam sprocket lined up with the dot on the crankshaft sprocket after you installed the timing chain.
Again since you said it ran fine I'd bet you dbl check, but just thought I'd ask?
#25
ORIGINAL: ALMOST STOCK
Here's the update! I put my timing to 16 degrees now and started the car up and it was fine. Timing is dead on now... I drive it down the street and the car is smoking from the passenger side of the car. It's not bad but smells like burning.
Now my o2 sensor is touching my starter and it barely wanted to go into the whole in the midpipe. So when I was driving down the road when it was smoking I did a U turn and when I put the car in reverse, it just shut off... Now the car won't start again.... I wait a little bit and start it and walah it starts again and idles fine. I drive it home... Now i'm not sure why it just shut off like before, but I think the smoke is coming from the o2 sensor touching the starter...
Not sure what to do!
-Jeff
#26
Guys theres no such this as being one tooth off with our efi cars since you can clock the distributer to get timing back to perfect. Sounds like your just not getting timing close. If you need to know how to drop the distributer in correctly Adder has a tech article on how to do it at the top of the 5.0 section.
#27
you can be one tooth off if you marked everything up and are being **** and can't get it back exctly where it was before....like I said before he just needed a light to time it back in.
As far as the running problem, how much run time do you have on it? I won't run perfect as the ECM learns your new set up. Try and reset the ECM then start it and let it idle for about 30 minuets till it get warm so it has a little time to learn. You will need a couple hours of run time.
#28
One tooth off
The "stock" angle of the TFI is where it points at the driver's side headlight. This sets the proper position for the distributor base. Then put #1 piston at TDC and re stab the distributor to align the distributor rotor with the #1 distributor cap terminal. If you are on either side of the #1 terminal (see illustration below) you are likely "one tooth off". This can be corrected by either moving the distributor base to correct timing (moves the angle of the TFI) or re stabbing the distributor rotor. The "one tooth off" thing relates to the factory position for the distributor base (TFI angle).
#30
ORIGINAL: 5.0stanger
but you can turn the body where ever you want...problem solved.
EDIT- but yes, you can technically be off one tooth.
