Ok, I really need help with this..
I'll start my car, drive it around a little, once it gets warm or hot (I have a 190 thermostat) it will drive really crappy (Start shaking like I'm starting off in the wrong gear) or not drive at all, If I turn it off it will not start at all, the motor will turn but it it acts as if it has no gas.I've changed out the fuel filter thinking that was it but the same problem is going on. Any idea's? Thanks.
RE: Ok, I really need help with this..
My 1993 did the same thing <does the Tach jump around? You my want to pull the distributor cap and check to see if the pick up (PIP) is rubbing the stator or if it is loose.If it is loose you found your problem. good luck
kraigmak721
08-11-2007 10:52 AM
