Fuel pump location
Fuel pump location
hey guys i have an 82 GT and the fuel pump finally went.(only had about 21/2 psi. well good and bad. bad because more money gone but good because it's finally time to go electric. only problem is there isn't really a decent location to put it. it says too keep it low and close to the pump. i was thinking about making a braket to bolt on the the tank itself and attach it to that. Good idea or not. i don't know. ive never had to switch from mechanical to electric before.
RE: Fuel pump location
ORIGINAL: pletch
i mounted mine on the fender near the mech. pump easy hidden just cut the metal supply line and attach the pump supply to carb supply
place the pump as close to the tank as possible it's easier to push fuel than pull it. I went with the holley blue pump and made brackets and mounted it behind the rear bumber and spare tire well.
just completed rebuild on an 85gt. New FRPP 302 w/Al heads, edel perf mani and carb, tube coated headers.
Burnt out 2 elect. Mrgaskets mounted near the old mechanical on the chassis (low).
Fed up - nobody seemed to know anything about what to do, here in Massachusetts.
So I mounted a Holley 801 Red just in front of the R rear tire inside the rocker panel space there - nicely protected, and
accessible from the bottom. Then ran -8AN braided hose from the tank to the pump, bolting it to the body over the rear housing, along
and around the subframe on the R to the front R wheel housing and up to the strut housing - attached to a Holley regulator and sent a
braided (Russell) line back to the tank; Have a Holley liquid in line pressure gauge after the regulator to the Edelbrock carb.
2 fuel filters - a jegs inline coming out of the tank above the diff. and another after the regulator.
Fuel pressure is 6 lbs and stable. F---- car runs GREAT!!! Can't thank that nice Ford replacement engine at 150 k enough.
I just love this Ttop.
Pump is now low (9 inches above ground, and protected, same level as bottom of tank)
Good luck.
Good luck.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
