Finally Installed!
Old 07-15-2007, 12:50 PM
gearbanger
gearbanger's Avatar
Default Finally Installed!
I got another rearend with a auburn pro carrier,richmond 3.73's, and moser axels.... took me 1 fullday to install it... it pulls hard, it's a big jump from 2.73's. i kinda miss my long first gear but its well worth the sacrifice..... but i might have a samll problem. it has a small howl when i leave it in gear and keep my foot off the pedal... is this normal for richmond gears? i'm hoping to get atleast 13.5 but i will soon find out on wendsday
gearbanger is offline
Old 07-15-2007, 05:27 PM
stang8689
stang8689's Avatar
Default RE: Finally Installed!
sweet, a gear change is the biggest improvement
stang8689 is offline
Old 07-15-2007, 05:29 PM
mattdel
mattdel's Avatar
sounds like the pinion torque is wrong
disconnect the driveshaft from the rear and check the torque to spec on the nut right there.
mattdel is offline
Old 07-16-2007, 12:52 PM
gearbanger
gearbanger's Avatar
ok i will try that. also found out that m drive shaft needs to be re-balanced[:@]... but its good 1st,2nd,3rd pull hard. first spins out secnd spins go into third and chrips hard... that pro carrier unit kickes ***...
Old 07-16-2007, 01:55 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
howling usually means something is not set corectly +1 for mattdel comment
FivePointOhh is offline
Old 07-17-2007, 02:02 PM
gearbanger
gearbanger's Avatar
ORIGINAL: mattdel
what would the torque spec be?
Old 07-17-2007, 03:09 PM
mattdel
mattdel's Avatar
hell if i know, i havn't installed gears in a few years...
make some calls
mattdel is offline
Old 07-17-2007, 09:11 PM
stocksuspension
stocksuspension's Avatar
torque spec has nothing to do with a howl, his back lash is off, ur hearing that howl at 55 mph under light load
ORIGINAL: mattdel
stocksuspension is offline
Old 07-17-2007, 09:13 PM
stocksuspension
there is no tourque spec! just hold the flange and zap the *** out the nut
Old 07-17-2007, 10:45 PM
gearbanger
gearbanger's Avatar
i only hear the howl when its in gear and i let off the gas... when i'm excel i dont hear anything
Quick Reply: Finally Installed!
