24lb MAF meter needed
Hey mustang pepz, I need a 24lb calibrated MAF meter super bad. My stang is running really lean with the stock 19lb'ers... Can anyone help? My email is wholesalecovers@yahoo.com email me if you got one reasonably priced...
Thank you
Thank you
RE: 24lb MAF meter needed
Are you saying you need injectors of a MAF? Jusding by your sig, you already have a 75mm MAF. Why not just get that recalibrated? But your sig also shows that you only have 19# injectors. Getting a MAF calibrated to 24# injectors is only going to make things worse if you still have 19# injectors.
Nah I have a pro-m 19# meter and stock 19lb injectors atm I can't find anyone to recalibrate it for me. I have a set of 24lb injectors I want to put on but need the matching MAF : ) Know anyone that calibrates prom meters? I heard prom went out of business
goto summit racing and get the granatelli 75mm maf calibrated for 24# injectors, its what i have and works good, its like $250 i believe. its a 75mm also. or get the c&l and you can get the calibrations which are cheaper then buying a new maf if you plan on going bigger then 24#.
If I recall correctly, you can send it in but they charge $100 for the recalibration. I wish I could remember the company that would do it for you. You may want to check with http://www.granatellimotorsports.com/ to see.
SteelerNation82
09-09-2015 09:06 AM
