WHICH CAM??????
Old 07-27-2007, 01:39 PM
capri_83
capri_83's Avatar
Default RE: WHICH CAM??????
77 it's a 90 roller block with roller cam...that why I'm having issue with finding a cam...I've put on better springs on valves.....so lift not that much of issue....It will go .564 no trouble.....with my 600 carb. I was running out of fuel......major high rpm misfire...
capri_83 is offline
Old 07-27-2007, 01:40 PM
luizGT91
luizGT91's Avatar
correct me if I´m wrong but the best part of the cam is the duration? i changed the X303 for a F303 ´cause it had more duration, less lift
luizGT91 is offline
Old 07-27-2007, 01:45 PM
capri_83
capri_83's Avatar
Luiz that what I think the cam in the car has only 208/218 @ .050 lame!!!
capri_83 is offline
Old 07-30-2007, 09:23 AM
capri_83
capri_83's Avatar
So installed a x303 ford racing cam on sat. and wouldn't you know it stumble.....carb issue.....all gone.......went to track on sunday and ran a 13.1 no bottle......finally [8D][8D]
capri_83 is offline
Old 07-30-2007, 12:01 PM
luizGT91
luizGT91's Avatar
what are your mods buddy
luizGT91 is offline
Old 07-30-2007, 06:35 PM
capri_83
capri_83's Avatar
I run a 90 roller block....heart shaped heads.....10:1 forged pistons.....compcams 926 springs......compcams 220 duration @.050 and .512 lift cam......1.7 roller rockers......4.10 gears....t-5.....275/40r17 on the rear.....17x9 cobra wheels.........31 spline axles....and full msd box and dist... the 100 shot has not gone on the car this year so far...I will try to get some good pics this friday at the track and post them....
capri_83 is offline
Old 07-30-2007, 07:46 PM
my77stang
my77stang's Avatar
thats either valve float, or crappy timing / ignition components
my77stang is offline
Old 07-31-2007, 09:48 AM
capri_83
capri_83's Avatar
Or fuel starvation so says the a/f meter.....
capri_83 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: WHICH CAM??????
