new fuel pump ?
new fuel pump ?
Ok, I installed my 255lph fuel pump and now when i'm at wot my air/fuel is around 10-11 instead of 12.2 like I got it tuned...
I was thinking it shouldnt have changed since i didnt mess with my fmu or my fpr.. why do you think it changed? attached is my dyno sheet
RE: new fuel pump ?
maybe you were maxing out the stock pump and just by luck it was runing a 12.2 afr. then when you put in a pump that can feed a lot more fuel, it filled the lines and rails to their max giving a richer afr.
on a return style fuel system, adding a bigger pump shouldnt effect afr because non needed fuel will go back to the tank.
mrappe
09-26-2015 10:16 AM
