having trouble firing motor
Old 07-26-2007, 10:36 PM
pbguns
pbguns's Avatar
Default having trouble firing motor
i just rebuilt my motor and im having trouble firing it i sound like it wants to turn over but i keep bending push rods can ne body help me
pbguns is offline
Old 07-26-2007, 10:53 PM
mattdel
mattdel's Avatar
Default RE: having trouble firing motor
are you using hardened pushrods? correct length?
what consists of the rebuild that you did?
mattdel is offline
Old 07-26-2007, 10:57 PM
my77stang
my77stang's Avatar
umm....
"it sounds like it wants to turn over but it keeps bending push rods"
sounds to me like pistons are hitting valves and the pushrods are taking the fall. probably have bent valves too if this is whats happening. what head/piston/cam combination do you have?
my77stang is offline
Old 07-26-2007, 11:03 PM
pbguns
pbguns's Avatar
i havethe valves arnt hitting the pistons I had to get new pistons for ttat reasoni have speed pro piston that clear the valves im not using hardened push rods im using stock length push rods im not sure if they are the right size but i dont know what size i should go with
pbguns is offline
Old 07-26-2007, 11:05 PM
my77stang
my77stang's Avatar
even if they arent harded they shouldnt be bending. the hardening just keeps them from getting chewed up while rubbing against the guideplates. sure, they are stronger - but something is happening for you to be bending them. did you screw up installing your timing chain and have your cam opening at the wrong time?
pbguns
pbguns's Avatar
my heads are canfield 192 cc heads they flow 283 at .600 lift my cam has a lift of only .512
pbguns is offline
Old 07-26-2007, 11:07 PM
pbguns
pbguns's Avatar
i checked the timing chain i set the number one clinder to top dead center and set the timing chain perfect
pbguns is offline
Old 07-26-2007, 11:09 PM
mattdel
mattdel's Avatar
top dead center on the exhaust or compression stroke....
mattdel is offline
Old 07-26-2007, 11:11 PM
pbguns
pbguns's Avatar
compression
pbguns is offline
Old 07-26-2007, 11:14 PM
mattdel
mattdel's Avatar
pre-mature coil bind?
are all the pushrods bending or is it the same one in 1 spot.
mattdel is offline
Quick Reply: having trouble firing motor
