Need help on some rack&pinion bushings.
Old 07-27-2007, 09:42 PM
monkeyboy
monkeyboy's Avatar
Default Need help on some rack&pinion bushings.
I almost got my suspension all back together tonite.... Well... until I ran into a problem[:@]. I removed my bushings from my rack and pinion and was getting ready to put in my off-set bushings. But the instructions say to re-use the inner sleeve. There's no way that sleeve will fit in my bushings! (Only if I drill out the hole bigger.) I've never heard of it.... But is there any differences in the rack&pinion units on foxbodies? Or does my car have some cheap replacment unit in it? The mustang I'm working on is an '85 GT with power steering.
monkeyboy is offline
Old 07-27-2007, 11:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Need help on some rack&pinion bushings.
differences were was it standard or sport suspension for options......just means on the sport suspension lock to lock had a shorter travel. get some silicone spray and you might get them to fit but without seeing exactly how large the difference is , it's hard to make an accurate guess
mjr46 is offline
TacoBill
01-24-2012 10:01 AM
oxfordgt
30
12-04-2008 04:06 PM
68pony5
04-06-2007 11:28 PM
5.0kidsdad
04-03-2007 02:59 PM
ZachW04Stang
10-11-2005 08:22 PM
Quick Reply: Need help on some rack&pinion bushings.
