Lowering w/o c/c plates
Old 07-29-2007, 07:36 PM
LOUDexhaust
LOUDexhaust's Avatar
Default Lowering w/o c/c plates
I want to know how much I can lower my stock 91 GT w/o requiring c/c plates. Right now I am thinking about getting Vogtland , pro kit, or these. Right now I have a little over 3 inches between my tire top and fender. With my new wheels I will lose about a third of an inch in the wheel well. So my goal is to lower this thing without screwing up the alignment.
LOUDexhaust is offline
Old 07-30-2007, 10:31 AM
LOUDexhaust
Default RE: Lowering w/o c/c plates
bump
Old 07-30-2007, 12:44 PM
89 fox
89 fox's Avatar
i lowered mine with the Steeda Sport kit (1 1/2" drop) and didn't need em
89 fox is offline
Old 07-30-2007, 04:15 PM
Jfsram
Jfsram's Avatar
Your question is loaded because it really depends on how much negative camber you are willing to put up with.
My Mustang has Eibach sportlines. I think it's a 2" drop. I have major neg caster 3.5 deg.
Is - 3.5 camber too much? Not bad for autocrossing or a short trip Sunday car.
Skinny front tires will also forgive lots of positve or negative camber.
I have the exact opposite. Mine is a daily driver with widelow profile tires. I'm killing the insides ofmy front tires. It's too bad though because it handles like it's on rails.
Jfsram is offline
Old 07-30-2007, 05:02 PM
Maxwelhse
Maxwelhse's Avatar
I put camber bolts on my struts when I installed my FRPP B-springs. I would estimate that I got about 1" of drop out of them and it definately needed something to correct the geometry. Camber bolts aren't the best way to go (I will do plates when I do the struts), but they're cheap and will get ya by.
Maxwelhse is offline
Old 07-30-2007, 06:01 PM
LOUDexhaust
So the stock equipment doesn't allow for camber adjustments?
Old 07-30-2007, 06:08 PM
945LSTANG
945LSTANG's Avatar
ORIGINAL: LOUDexhaust
no, it allows for camber adjustments, just not enough adjustment for a lowered car.
945LSTANG is offline
Old 07-30-2007, 06:45 PM
ZachW04Stang
ZachW04Stang's Avatar
I have my car lowered 3 or 4 inches in the front with coil overs and I have camber and toe in spec without plates. Caster is close, all I had to do was loosen the k member bolts and shift it forward. I do have plates though that I'm putting on thursday.
ZachW04Stang is offline
Old 07-30-2007, 11:56 PM
LOUDexhaust
I'm going to get some springs that will lower about an inch. Now I need to get shocks. Will stock replacements work or do I need to get something different?
Old 07-31-2007, 08:02 AM
Jfsram
Jfsram's Avatar
ORIGINAL: ZachW04Stang
Is there reallythat muchslop in the K member bolt holes Zach?
How muchcaster, camber were you able to achieve with this method?
Jfsram is offline
Quick Reply: Lowering w/o c/c plates
