going into reverse?
going into reverse?
i just picked up my new 88 5.0 last week and it would grind when i put it into reverse, i was talking to my buddy at work who has an 89 and his does the same he said if you put it into any other gear first then into reverse it doesnt grind so i tried it and sure enough it doesnt grind does anyone know why it does that??
thanks
thanks
RE: going into reverse?
Yep mine will do it every single time if i dont put into first then into reverse. Thats kinda good thatim hearing everyone else's stang does it too, thought the synchros might be going in it
revers doesnt have a synchro, so you dont put it in reverse by accident while going forward, you might try double clutching, heres a full tutorial for those of you who are oblivious
in neutral, let the clutch out, all the way, give it a little gas, depress the clutch, put it into gear, may or may not work for reverse, meant for going forward
thankk godd!! i thought my car was messed up, it wasnt as bad when i just got it but its getting worse, sometimes it wont go into first also,
i will be changing my shifter i wonder if that would help?
