GT40P ENGINE SWAP DONE!
RE: GT40P ENGINE SWAP DONE!
ORIGINAL: VigCS
As did I with my TFS cam and P heads. They work well, but I'm using stock rockers.
ORIGINAL: drhoward
I used stock length hardened push rods with my p heads 1.7 rockers and a tfs1 cam, it seems to work well
I know I should get the custom length ones I have just been too lazy lately
ORIGINAL: 94 G STANG
you and a handful of others on this site have, im wondering maybe my rockers are bad? they were used i bought from e bay, crane cams type "same as in 94-95 cobra". I asked a few guys here that work on engines and they all said stock length should work.
a month ago from reedracer on ebay, another thing i noticed is they have numbers on them in the middle of the rocher on the pushrod side 12 of them had the number one on them and four of them had a 2 does that mean anything,
and if longer pushrods isnt the solution what is ? adjustable studs?
and no my plug wires are not burned i used accel wires wich i had to cut and put toghether worked out ok, but i still used zip ties and i cut a 6 inch long rubber hose and put it around the boot just in case.
It sounds like you have a used motor with a few collasped lifters, resulting in excessive valve lash.
Id remove the intake and replace the lifters at the problematic valves. happened to me, the bores were worn on the inside, I like to here a motor run before I buy it.
i did replace the lifters, i used my old ones wich did not make any noise, my old engine the rockers were tight, i took out the lifters and
put it on this motor but same thing.
were you comfortable adjusting your valve lash? and did you soak your lifters in oil for a day before install
