under drive pulleys
Old 08-01-2007, 08:01 PM
pat
pat's Avatar
Default under drive pulleys
hey guys is it true that having under drive pulleys makes your battery run low voltage? and if your driving for a while and shut it off and try to start again it wont start? if so what would i have to do to prevent this problem? because im stuck with these for now do i have to make sure i have someone around to jump my car? what do you guys do?.
thanks
pat is offline
Old 08-01-2007, 08:03 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: under drive pulleys
yes it's true
use the stock alt pulley or carry a charged up jump box
nitrous_bob is offline
Old 08-01-2007, 08:10 PM
85GTsleeper
85GTsleeper's Avatar
ive had mine for months and i never had the car lose too much voltage to start my car.
85GTsleeper is offline
Old 08-01-2007, 08:21 PM
MEM 302 5.0L
MEM 302 5.0L's Avatar
just get a better alternator...that charges better
i upgraded to a 130 amp
MEM 302 5.0L is offline
Old 08-01-2007, 08:40 PM
Tony71502
Tony71502's Avatar
Ive had no charging issues at all with my UD pulleys, with an oem charging system. The only time the voltage is relatively low is when at idle.... but even with headlights, blower motor, and radio going at once I really have no trouble. I think its just somthing that happens with worn charging systems and people tend to blame the UD pulleys.... in addition to having a bunch of electrical stuff running.
Tony71502 is offline
Old 08-01-2007, 08:41 PM
chath_brick
chath_brick's Avatar
i've never even had the voltage dip in the least in my car, there is absolutely zero difference in charge since i installed them...but i have an sn-95
chath_brick is offline
Old 08-01-2007, 08:43 PM
MEM 302 5.0L
another way around it is to get aluminum pullies...not steel... they make them lighter instead of changing the size of the alternator pulley.....
Old 08-01-2007, 08:50 PM
chath_brick
yeah, i have the blue summit aluminum ones...they work great (anything more and you're just paying for the name)
Old 08-01-2007, 08:53 PM
92hatchLX
92hatchLX's Avatar
I never had an issue with my underdrive pulleys and charging issues (beforeI got rid of them for the s/c)
92hatchLX is offline
Old 08-01-2007, 08:57 PM
chath_brick
pfft, just an excuse to brag about your s/c
Quick Reply: under drive pulleys
