easy dumb ?
Old 08-03-2007, 11:19 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: easy dumb ?
you shouldnt run that stat anyway.... its a 160. Either clean it off and try to return it, or toss it in the garbage
AdderMk2 is offline
Old 08-09-2007, 11:54 PM
reddogg
reddogg's Avatar
sorry guys, your wrong. without a t-stat the car would be more likely to overheat because the tstat slows the flow of coolant down. without any restrictions to flow the water passes through the radiator too fast and does not have time to cool off. radiator is a air to liquid heat exchanger.
reddogg is offline
Old 08-10-2007, 12:00 AM
onetrickpony
onetrickpony's Avatar
ORIGINAL: reddogg
Oh Shyt, your fukked now. You said the wrong thing to the wrong person ^^^^^^^^^^. What hes forgotten you have to learn.
onetrickpony is offline
Old 08-10-2007, 12:12 AM
reddogg
reddogg's Avatar
sorry didn't mean to make any one mad, let me clear up my statement. didn,t me that was the answer for the overheating issue, just that not running a t-stat at all is not a good idea.
reddogg is offline
Old 08-10-2007, 12:17 AM
kilby94
kilby94's Avatar
ORIGINAL: reddogg
Without the thermostat restricting the coolant flow the coolant wouldn't have enough time in the engine to get as hot. The t-stat holds the coolant in the motor longer so that it will heat up to a certain temp, then lets it flow to cool off. Without the t-stat it would be constant circulation of coolant therefore never getting as hot. I would think it would still have plenty of time in the radiator to cool down. Don't see how not having t-stat would make it run hotter?
kilby94 is offline
Old 08-10-2007, 12:35 AM
reddogg
reddogg's Avatar
when the coolant comes into the hot motor the thermastat also adjusts and closes. if the coolant did not remain in the radiator long enough to cool off you would defeat the purpose of the radiator. for instance without a t-stat you would be circulating hot coolant into the heads and block that are continuosly becoming hotter and your coolant can not absorb all the heat and boil. just passing through the radiator is not enough it has move at a certain speed to cool off, that is the t-stats job.
reddogg is offline
Old 08-10-2007, 10:45 AM
creekrat
creekrat's Avatar
Sorry reddog, I think you are wrong. In racing engines, they do not run t-stats, as that is just one more thing to go wrong. Instead they use large washers to fill the hole where the stat would be, with different size holes in them which allows the water to come up to temp quicker. Running without one will not allow the motor to come up to temp to even worry about spending enough time in the rad to loose its heat load. Try it one time! been there and done that.
creekrat is offline
Old 08-10-2007, 03:33 PM
AdderMk2
Banned
AdderMk2's Avatar
reddog is half right... at idle, a car with no T-stat will not properly cool down. but at highway speeds, the air forced through the radiator will keep the car cool. sometimes TOO cool
AdderMk2 is offline
Old 08-10-2007, 06:34 PM
94StinkinLincoln
94StinkinLincoln's Avatar
yeah adders right on this one. if ur in traffic and no t-stat ur gonna have one hot motor.
94StinkinLincoln is offline
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
baddog671
07-26-2016 01:20 PM
TimeLord101
10-01-2015 06:40 AM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: easy dumb ?
