electrical problem
electrical problem
hi there, if you could help i would be extremely gratefull. so heres to problem.... i have an 88' gt i've always had stupid **** go wrong with it but over the past few months i've gone through a number of starter soleniods, and every time i put a new one in it works fine for a while. about a month ago i changed out my spark plugs, rotor, cap and adjusted to timing. after that i went out to drive it and see how i like to timing adjustments i had made. for a while now after i had added mass air, and gt-40 upper and lower manifolds the car will try and die on me at stop lights. as i was trying out the timing adjustments i had made, the car died a couple of times and a light, on the last time i couldn't get it started up again. after replacing the stater solenoid, starter, pulling and cleaning the main ground, and power lead to the starter i am still getting the same problem. after charging my battarie i can turn the power on the all the excessories, like headlights, convertable, radio, etc.... however when i got to engage to solenoid to the starter, there is a faint pop and nothing happens. after this happens, i can no longer turn power to the eccesories and i have to recharge the batterie. there is nothing on that side of the solenoid exept for the lead to the starter. obviously its and electrical problem and there must be a short some where that is killing the ground. but i have pulled the ground and the lead to the started and wrapped them with electrical tape and still i get nothing. if anyone has any ideas, or previous experience with this problem, please give me a hand, because i just don' know what else i can do. thank you
RE: electrical problem
if there is a pop and then nothing happens, that means that you have a loose connection somewhere. I know this is basic but are your battery terminals tight? Check the ground on the firewall from the drivers side head, that was my issue. Hope this Helps.
ORIGINAL: ahittz24
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
TfcCDR
09-14-2015 12:08 PM
