Clutch install questions
Old 08-08-2007, 01:49 PM
ISwearItsStock
ISwearItsStock's Avatar
Default Clutch install questions
So my throwout bearing went up, so I ordered a King Cobra clutch kit. My question is, what are the torque specs for the clutch disk, pressure plate and transmission. Going to my buddy's work sunday to use his lift, so i wanna have all the info I need.
ISwearItsStock is offline
Old 08-08-2007, 04:59 PM
stang8689
stang8689's Avatar
Default RE: Clutch install questions
check haynes manual, I can't think of it of the top of my head-sorry
stang8689 is offline
Old 08-08-2007, 05:33 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
ORIGINAL: stang8689
checkChilton manual, I can't think of it of the top of my head-sorry
fixed that for ya
FivePointOhh is offline
Old 08-08-2007, 06:46 PM
89 fox
89 fox's Avatar
don't know the specs off my head...but do yourself a favor and buy a new TOB....i have the KC HD kit and the TOB is $hit!! i had to change it again before i even got to drive it....go get a Timken from Autozone
89 fox is offline
Old 08-09-2007, 12:56 AM
cleanfitty
cleanfitty's Avatar
The KC kit comes with the self centering design which is sort of offset. The tech bulletin says you must use this type of design or it will make an awful noise. I believe the TOB that comes in the kit has an E7Z part number so it would seem it is factory. There shoudn't be any issues with it as long as the fork is good.
I think the flywheel to crank is 75-85, the pressure plate is like 12-24. Look up the clutch on summitracing.com and look at the tech bulletin at the bottom of the page.
cleanfitty is offline
Old 08-09-2007, 02:55 AM
bzlover
bzlover's Avatar
How did your car feel when the throw out bearing went out..?
bzlover is offline
Old 08-09-2007, 10:53 AM
ISwearItsStock
ORIGINAL: bzlover
When i pushed the clutch in it started with a whine, then by the time i got home it sound like someone raping a cat. Didn't completely go out, but it's close
Old 08-09-2007, 11:13 AM
bighungrymatt
bighungrymatt's Avatar
ORIGINAL: ISwearItsStock
ORIGINAL: bzlover
I bet that sounded HORRIBLE lol
bighungrymatt is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
whatsup62
08-29-2015 01:25 PM
ponyride00
08-12-2015 01:57 PM
Quick Reply: Clutch install questions
