hypereutetic or forged?????
Old 08-09-2007, 12:51 PM
my77stang
my77stang's Avatar
Default RE: hypereutetic or forged?????
you want flat tops with vavle reliefs for a n/a motor, but with forced induction you want something dished
stock rods are fine, but take my word on this..... use ARP bolts. preferrably the 100.00 set not the 40.00 set. the 5/16 rod bolt is one of the two weak links in the small block ford. the other is the oil pump driveshaft, which you should replace with a hard arp unit cause they are like 20 bucks.
you need to get your rods reconditioned too, and let the shop install the bolts
my77stang is offline
Old 08-09-2007, 05:04 PM
ant0045
ant0045's Avatar
well the only the pistons they have on summit in the kit are the flat top. i only want to go with a 6-8psi s/c. and also i need them to install the rod bolts bc y. im going to have to take them back out to put everything together. and can i get the oil pump drive shaft from summit????
ant0045 is offline
Old 08-09-2007, 06:45 PM
67mustang302
67mustang302's Avatar
If you have the money some upgraded rods wouldn't be a bad idea, to get the floating pin setup. It's good insurance with a blower, but not necessary. And yeah, at the very least the good rod bolts and a hardened oil pump shaft. Definately forged pistons for blown/nitrous, hypers tend to not hold up too well under the heat
67mustang302 is offline
Old 08-09-2007, 06:47 PM
tinman
tinman's Avatar
Summit sells the oil pump drive shaft. They also have the rod bolts.
IMHO, with the cost of rebuilt rods what they are (easy$250 with the good rod bolts) why not just get some new rods? New rods are as little as $200 set.
I'd call Summit and find out what the upgrade to the dished would cost as I'm sure they have them..........
tinman is offline
Old 08-09-2007, 07:15 PM
ant0045
ant0045's Avatar
im using the rods out of a motor that has 1100 original miles on it....the entire motor...
ant0045 is offline
Old 08-09-2007, 07:35 PM
67mustang302
Scat has forged light weight i-beam rods with floating pins and ARP bolts in them for like, just under $200 I think
Old 08-09-2007, 07:39 PM
AdderMk2
Banned
AdderMk2's Avatar
I would avoid the speed pro rebuild kits... but thats just me
AdderMk2 is offline
Old 08-09-2007, 09:39 PM
stang8689
stang8689's Avatar
you don't need rods just throw them away
stang8689 is offline
Old 08-09-2007, 10:05 PM
my77stang
my77stang's Avatar
just remember the 200.00 rod sets from summit are gonna have the cheap arp bolts, i just picked up a set of these for my 289 rods which i polished to stress relieve (strange how taking away meat can make them stronger)
http://store.summitracing.com/partde...p;autoview=sku
these are the best 5/16 bolts you can buy
and btw, there is nothing wrong with speedpro stuff, its pretty much the best bang for the buck stuff out there. sure, there are better forged pistons than the trw/speedpro/federal mogul's but you'll pay close to double and 9 outta 10 people would never know the difference. they do not make crap parts.
Old 08-11-2007, 08:33 AM
ant0045
ant0045's Avatar
alright i ordered the speedpro flat top pistons forged and scat forged rods with arp bolts along wiith the arp oil pump drive shaft. shuld i still order different arp bolts?????
ant0045 is offline
Quick Reply: hypereutetic or forged?????
