Backfire problem
Old 08-10-2007, 03:38 PM
Alero99
Alero99's Avatar
Default Backfire problem
Well since i have had the car its been backfiring... i had a new fuel pump put in, felt great at first, then it started backfiring and there were dead spots, id hit it and nothing happened
So i bought a Adj fuel pressure regulator from Kirban...
had it in felt a little better but im having the same problems
Before the new fuel pump i was running at 20 or so PSI fuel pressure
could running that lean have damaged my spark plugs or wires?
somthing just isn't right.
Full Exhaust and the fuel pump and reg are my only mods, and a new rack and pinion steering.
Alero99 is offline
Old 08-10-2007, 04:34 PM
mattdel
mattdel's Avatar
Default RE: Backfire problem
i suppose when you had the tank down, you didnt bother to check if the fuel pump baffle was still in place inside the tank.
check the MAF sensor wires too, if they aren't as white as a piece of paper, clean them.
mattdel is offline
Old 08-10-2007, 05:44 PM
crocop
crocop's Avatar
ey try the fuel filter it just worked for me. that is if you have a problem with the intake.
crocop is offline
Old 08-11-2007, 01:33 AM
Alero99
Alero99's Avatar
well, i purchased a BRAND NEW tank, cuase the baffle in my old tank was broken. i really hope the baffle has not broken again. my cousin had noticed tonight on turns it does it alot, but also while im cruising, ill feel the car dieing then i punch the gas a little and itll POP and go normal again.
Alero99 is offline
Old 08-11-2007, 07:55 AM
aode08
aode08's Avatar
put a half tank of gas in her, then hit corners, this will tell you.
aode08 is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Backfire problem
