amazing power gains from a diff tuner
RE: amazing power gains from a diff tuner
ORIGINAL: samseed101
Richen it up a bit in the fuel tables, adjust the timing at the spark tables (not just by turning the dizzy), add a couple more PSO of boost, make sure hte belt is nice and tight, and there you go.
I thought the leaner a car ran the more power it made???
ok its the 5.0 gt40headed fordracing performance parts crate engine, i have a trick flow street heat intake upper and lower with a 1inch spacer between, bbk 75mm tb, egr bypass, bbk shorty headers i believe they are 1 5/8, bbk off road hipe and 40 series flowmasters, vortech v-1 s trim blower with afm power pipe and 76mm maf, with 42lbs. injectors, and im running at the moment 13#'s boost, timing is locked out at 29 degrees (spout is out), and air fuel ratio at WOT is 11.3 to 11.4and i was making 474.4 on the dyno, the tuner had the a/f at 12.2 and it made 494 and my dad told him to take it back down for reliablity reasons
ORIGINAL: 5.0kid
Let us know how it works out at the track....be careful launching all that extra Power
yeah im working on getting a t/a rear end girdle and a swarr bar to help with that but i dont side step anyways i just feather it out and punch it off
Daddys Girls GTs
09-14-2015 08:46 PM
ernesto-619
09-10-2015 01:32 AM
