temp question?
Old 08-14-2007, 04:52 PM
steel1
steel1's Avatar
Default temp question?
Just flushed the radiator, put in a 180* stat, new coolant and water wetter. Everything went fine, no leaks or coolant loss. I have after market gauges and my temp seems to run between 205-210* , is thisnormal? Car has never overheated and I still have the stock radiator,water pump and some mild mods. Car seemed to be running hot with stock gauge, so that is why I went ahead with new gauges and figured I would change coolant and stat.
steel1 is offline
Old 08-14-2007, 04:59 PM
86 5.0L
86 5.0L's Avatar
Default RE: temp question?
maybe the pump is on its way out
86 5.0L is offline
Old 08-14-2007, 05:10 PM
mattdel
mattdel's Avatar
did you mix the coolant with water? or just slap a couple gallons of antifreeze & the water wetter
mattdel is offline
Old 08-14-2007, 05:26 PM
tmajikman
tmajikman's Avatar
How is the fan, does it always run at that temp, at idle or when cruising on the highway. Did you replace the radiator cap when you changed the coolant?
tmajikman is offline
Old 08-14-2007, 06:32 PM
steel1
steel1's Avatar
Mixed 60%water 40%coolant w/water wetter, stock fan is fine always runs, but I did not replace the cap, guess I'll give it a try. So from the response I'm getting, I guess this temp is too high? Water pump isn't making any noise, nor does it leak.
steel1 is offline
Old 08-14-2007, 06:36 PM
mattdel
mattdel's Avatar
205-210 is the factory desired running temp, for emissions purposes, but with the 180 you should be running about 195, which would gain you a couple ponies.
mattdel is offline
Old 08-14-2007, 07:02 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: mattdel
Yup, mine runs around 195. What's the inside of the radiator look like. Any corrosion on the tubes?
PRO50SC is offline
Old 08-14-2007, 07:06 PM
tmajikman
tmajikman's Avatar
mine runs right at 190 as well.
Old 08-14-2007, 07:16 PM
steel1
steel1's Avatar
When I look in the radiator I can see some white (what looks like corrosion?) on the ends of the tubes, but they are not blocked
steel1 is offline
Old 08-14-2007, 07:21 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
that temp is fine... mine runs at a 190-210 on a regular basis.... cooler would be better but its not neccesary... for a stock engine it might be to warm tho... i had a h/c/i with lts at the temp
CrazyCobraSpeed is offline
Quick Reply: temp question?
