roller rocker stud size
Old 08-20-2007, 03:55 PM
silentvoice19
silentvoice19's Avatar
Default roller rocker stud size
i have a 92 gt 5.0 with the 7mgte heads and im looking for 1.7 roller rockers what size threads are the studs???? All i see is 7/16 and 3/8ths and i heard i cant use the stud mounted roller rockers so if i can use those which ones can i?
silentvoice19 is offline
Old 08-20-2007, 04:33 PM
my77stang
my77stang's Avatar
Default RE: roller rocker stud size
your heads are E7TE, and you need to either buy pedestal style rockers (they bolt onto the heads via a 5/16 bolt), or a stud conversion kit which has 5/16 threads on the bottom and 3/8's on the top. then you can use stud style rockers.
if it were me, i would get the stud converstion - cause later if you decide to get aftermarket heads you dont have to buy new rockers. also for what its worth, the crane energizers are probably the best bang for the buck you can find. stay away from the proform's cause they are crap, and the trick flows are overpriced.
my77stang is offline
Old 08-20-2007, 04:43 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: silentvoice19
this has got to be a first..... Toyota heads, on a 5.0!!!
that I have to see.... inline 6 heads on a V8
AdderMk2 is offline
Old 08-20-2007, 06:09 PM
tinman
tinman's Avatar
Comp Cams has that kit for the studs.......
tinman is offline
Old 08-20-2007, 06:28 PM
my77stang
my77stang's Avatar
yeah i guess i shoulda gave links huh?
100 bucks
http://store.summitracing.com/partde...p;autoview=sku
200 bucks
uedlose
09-30-2015 08:01 AM
09-25-2015 06:58 PM
09-25-2015 06:42 PM
09-25-2015 06:30 PM
Quick Reply: roller rocker stud size
