school me on cams
Old 08-23-2007, 02:44 PM
blackfox6886
blackfox6886's Avatar
Default school me on cams
im gonna be building a 331 with edelbrock performer rpm heads and performer rpm II intake. but im not sure as to what kind of came to get. i wanna cam thats gonna give me the most performance. the car is gonna be a driven 3-5 times a week and taken to the track almost weekly. so someone please school me on the duration/lift and how to decide what i need or you can recommend a certain cam. thanx in advance for the replies
blackfox6886 is offline
Old 08-23-2007, 02:52 PM
1991LX5.0
1991LX5.0's Avatar
Default RE: school me on cams
Well as for the obvious a custom grind will always be the best cam for your set up. But if your just looking for an off the shelf cam the choice will be limited by the PTV clearance. Areyour pistonsdished, flat top, etc?
1991LX5.0 is offline
Old 08-23-2007, 02:55 PM
aode08
aode08's Avatar
submit an online form through compcams etc. They have digital software, to match a cam to put you where YOU want.
For example, after giving all my info, I found that I need a SMALLER lift cam, with a LARGER DURATION profile. 112 split
The exhaust side needs to be 230 and the intake 224 with a intake lift of .498 and exhaust of .520 and a power
range of 1800-5200rpm, valve float 5,700 rpm. Torque and HP will follow VERY CLOSE together, all the way to top end.
and a good-noticeable idle to make it street friendly.
My goal was to pull from stall speed all the way to my rev limit.
The 4:10's sweetned the whole deal
aode08 is offline
Old 08-23-2007, 03:00 PM
blackfox6886
im gonna be runnin flat top pistons. how much more is a custom grind cam?
Old 08-23-2007, 03:08 PM
Joel5.0
Joel5.0's Avatar
331 stroker + driveable + the best performance = custom cam......you may want to check this alternative .... the best.....IMHO.
Joel5.0 is offline
Old 08-23-2007, 03:48 PM
1991LX5.0
1991LX5.0's Avatar
ORIGINAL: Joel5.0
couldnt agree any more. I got my custom grind from jay and im extremley happy with it. And as for price its 299 for a SADI core or 399 for a billet core. So your looking at about 50-150 more for a custom grind, to me it was worth it. Im running stock pistons and a cam with .567 lift with tons of PTV clearance. That wouldnt have been possible with an off the shelf cam without notching the pistons
Old 08-23-2007, 04:42 PM
blackfox6886
thanks for the helpful info
Old 08-23-2007, 05:36 PM
AdderMk2
Banned
AdderMk2's Avatar
why a 331.... why not a 347...
costs the same to build
AdderMk2 is offline
Old 08-23-2007, 05:40 PM
PJB
PJB's Avatar
I went with a custom ground cam from FTI.
PJB is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: school me on cams
