radiator upgrade
Old 08-24-2007, 10:54 AM
steel1
steel1's Avatar
Default radiator upgrade
I want to upgrade my radiator in my 93GT, the stock one has been flushed and I installed a 180* stat , water pump works fine, no leaks in system. Stock radiator does still have some crud in it and the car runs hotter than I would like, 205-210*. I'm trying to decide between a single row or double row aluminum radiator, both w/1inch tubes.My car just your basic intake,exhaust,maf,tb,cai,gear upgrades and will probably neversee 300hp. So I'm wondering if the 2 row would be overkill? Would the 1 row drop the temp 10-15* and save me some $$ or should I go 2 row for the extra $$. Oh yeah, I still have the stock clutch fan, which operates fine.
steel1 is offline
Old 08-24-2007, 11:18 AM
Chrisinkw
Chrisinkw's Avatar
Default RE: radiator upgrade
i am actually wondering about the same thing
I would have to change the t stat too is it better to go to a 180 deg one over a stock?
i just put a new water pump in the car
it smells and feels hot but the gueage never gets very highg so the guage might be done too
Chrisinkw is offline
Old 08-24-2007, 11:19 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
summit dual row alum. rad for 258. cant beat it. i have it and i run at 185-190 all day long with stock fan and no fan shroud. just as an FYI 205-210 is normal.
FivePointOhh is offline
Old 08-24-2007, 11:23 AM
FivePointOhh
in limbo
ORIGINAL: Chrisinkw
never rely on the stock gauges. my oil pressure always read almost nothing and temp was running always around the L in normal which i knew was wrong. installed aftermarket mechanical gauges and everything is right where it should be.
Old 08-24-2007, 11:33 AM
TwotoneVert
TwotoneVert's Avatar
I had to replace my rad last year, O-Riely has a 2 row HD for about 99.00. I was on a limited budget at the time. If you can swing it, Fluidine makes a great radiator.
TwotoneVert is offline
Old 08-24-2007, 11:38 AM
luckythirteen13
luckythirteen13's Avatar
get the two row
luckythirteen13 is offline
Old 08-24-2007, 12:06 PM
FivePointOhh
in limbo
ORIGINAL: TwotoneVert
fluidine = summit rad
Old 08-24-2007, 12:35 PM
ponyboy302
ponyboy302's Avatar
2 row is definately not over kill id even get a ford racing aluminum 3 row .. that with mild mods and the 180 youll never hit 200
ponyboy302 is offline
Old 08-24-2007, 01:12 PM
Chrisinkw
Chrisinkw's Avatar
why is the 180 deg thermostat better?
Old 08-24-2007, 01:33 PM
steel1
steel1's Avatar
I know 205-210* is considered normal, but I was trying to free-up a few ponies and run it cooler. I think I will go with the 2row, thanks for the help. In response to Chrisinkw... the stock stat was 195*, meaning it did not open and let coolant circulate through the radiator until the temp reach around 195*, the 180*starts this process at around ...180*, allowing the overall coolant temp to be lower. In my case my radiator has some blockage and I am not getting the full benefit. Lowering the operating temp. of the motor increases its ability to produce power.
steel1 is offline
Quick Reply: radiator upgrade
