Pullies
Old 08-24-2007, 11:32 AM
kevman41635
kevman41635's Avatar
Default Pullies
Does anyone know were i can get a stock set of pullies for the water pump and crank new or used my car has under drvie pullies on them and it is making it run hot i got the car with them so i do not have them the put them back.
Thanks
Kevin
kevman41635 is offline
Old 08-24-2007, 11:36 AM
samseed101
samseed101's Avatar
Default RE: Pullies
You can get a set of March pulleys on summit for about $150 or so. But why do you think that it's causing you to overheat? Lots of people run underdrive pulley kits and do not overheat. I had them myself for awhile before I went F/I and never had an issue either.
You can also go to just about any parts store or junkyard and get them as well.
samseed101 is offline
Old 08-24-2007, 11:43 AM
kevman41635
Default RE: Pullies
because i have put in a new raditor and did a full flush the car has a 180 tstat in it and it will run about 200 and if i go up a hill or turn on the a/c it goes to 215 or 220 then i turn off the a/c
Old 08-24-2007, 11:48 AM
SoDakStang
SoDakStang's Avatar
Default RE: Pullies
Underdrive pulleys slow everything down. It makes sense that it is overheating. IMO, they are a waste of money
SoDakStang is offline
Old 08-24-2007, 04:03 PM
creekrat
creekrat's Avatar
Default RE: Pullies
I got a set laying in the garage if you need them. $10 for them shipped to your door.They are of my '90, not sure what year you need them for.
creekrat is offline
Old 08-24-2007, 08:30 PM
kevman41635
Default RE: Pullies
is there a difference in a 90 to 94 in the pullies
if not then i will
Old 08-24-2007, 10:47 PM
creekrat
creekrat's Avatar
Default RE: Pullies
Not sure, I can check the apps for the od pulleys.
creekrat is offline
Old 08-31-2007, 10:58 PM
aru_next
aru_next's Avatar
Default RE: Pullies
Im running underdrives and I dont have any problems, try to flush out your system and get a new thermostat. if that doesnt work maybe you need a new water pump, then just go with a high flow, they are under $100 from summit and flow 30% more. good luck
aru_next is offline
Old 08-31-2007, 11:02 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Pullies
the fox pullies wont work.. sorry
why dont you try FIXING your overheating problem... instead of just tossing a bandaid on the situation
AdderMk2 is offline
Old 08-31-2007, 11:27 PM
Mustangkiler
Mustangkiler's Avatar
Default RE: Pullies
+1 and i sent ya another pm adder
Mustangkiler is offline
ctgreddy
09-20-2015 08:35 PM
GimpyHSHS
08-29-2015 06:30 PM
96mustanggt46
01-12-2004 02:52 AM
VicsGT
11-25-2003 07:07 PM
skatepony
07-30-2003 10:12 PM
Quick Reply: Pullies
