alternator swap?? 130 150 200?
Hey fellas i want to swap my alternator sincemy OEM finally$hit out on me. no what do you guys recommend? And what will i need to do to complete the instsall? ive searched and found so many different ways and fuses and such? someone steer me right.
thanx.
thanx.
RE: alternator swap?? 130 150 200?
130amp 3G is plenty and can be picked up relatively cheap if you look around.
do a search for " 3G alternator swap "
that will give you all the info needed. its easy and takes about 1-2hrs to do
including running power cable feeds and eveything.
Here, straight from the "Tech Artcls" section at top of forum section
https://mustangforums.com/m_1609872/tm.htm
ORIGINAL: blown/ho
Right on. i pretty much knew what to do. but the wiring is where im getting filed up?Any one have pics of the install. and where to get a good fuse.
did you even click on the link I posted ?????????
ORIGINAL: r.barn
ORIGINAL: blown/ho
noobs..[&o]
ORIGINAL: blown/ho
Sur did, i wanted to see some pix of where to locate the fuse. and what kinda fuse is that?
go to Circuit City back in the car radio dept., they sell high amp in-line fuses for stereo amps.
get a 120amp in-line fuse with holder case.
Matt's 95 Stang
10-05-2015 07:16 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
