???'s for Off-Road H-Pipe Install
Old 08-26-2007, 07:20 PM
daleclough
daleclough's Avatar
Default ???'s for Off-Road H-Pipe Install
I'm planning to remove the stock H-pipe in favor of an Off-road H-pipe. I will install the O2 sensors and that's about it.
Will the stock ECU adapt to this change without issue or am I in for more headaches after the switch? Any other issues going to come up or is this really a swap and drive?
Thanks!
daleclough is offline
Old 08-26-2007, 07:27 PM
URLACHER54
URLACHER54's Avatar
Default RE: ???'s for Off-Road H-Pipe Install
i cant answer your question but i want to ask whoever answers the question question. is it true by using a off road H or X pipe you will lose horsepower because of the lack of back pressure?
URLACHER54 is offline
Old 08-26-2007, 07:32 PM
primetime5.0
primetime5.0's Avatar
just a swap and drive, and no you wont loose to much back pressure
primetime5.0 is offline
Old 08-26-2007, 07:33 PM
daleclough
daleclough's Avatar
You lose some low-end torque but gain top end power.
Now, back to my questions.....
Old 08-26-2007, 07:34 PM
samseed101
samseed101's Avatar
You shouldn't have any problems after the switch.
To answer the other question... Typically, when you put an offroad pipe on you gain peak power but you may lose a little in the low end. But this all depends on what you're running and how much air you're putting through them. If you take a stock car and put on 3" offroad exhaust, then you aint gaining **** [8D]
samseed101 is offline
Old 08-26-2007, 08:04 PM
URLACHER54
URLACHER54's Avatar
which is more important top end or low end
Old 08-26-2007, 08:22 PM
Jmag034
Jmag034's Avatar
after putting my OR/H on my car feels sorta slow on the low end but its quick up in the powerband,
Jmag034 is offline
Old 08-26-2007, 11:53 PM
dimebag
dimebag's Avatar
car wont be effected because ur o2s are before ur cats anyway... one of the few good things about obd1...
and when i put on my o/r h and dumped flows... i felt no tq loss at all... and could feel the rpms climb slightly faster... only gained me .2 at the track tho... so no huge improvement... but it was for the sound
dimebag is offline
Old 08-26-2007, 11:55 PM
jakeachy
jakeachy's Avatar
backpressure doesnt mean anything. EXHAUST VELOCITY is the main concern.
jakeachy is offline
Old 08-26-2007, 11:58 PM
mattdel
mattdel's Avatar
backpressure means ALOT. go take your exhaust off from the headers back and run it, tell me what happens.
mattdel is offline
Quick Reply: ???'s for Off-Road H-Pipe Install
