transmission help
transmission help
i recently bought a '90 lx hatch from a friend, and unfortunately it's not in the best condition -- gas (aka money, amirite), oil, and transmission fluid leaks, as well as an iffy fuel pump [which is currently hooked up to a switch so the car can start once switched on].
i am keeping tabs on said leaks, and prepared with oil, transmission, brake, and power steering fluids along with fix-a-flat and bottles of water [for the radiator] to keep in the car. however, i cannot find where to put the transmission fluid! everything else is right there but for some reason i just can't find that, and i do not have the manual.
am i the only one with this problem, or is it common? i feel so dumb for asking. i really don't know anything about cars. ;>
also, i took pictures of the engine and labeled them if that helps at all.
full view: http://img212.imageshack.us/img212/9383/fullviewhg5.jpg
left view: http://img212.imageshack.us/img212/2231/leftviewor6.jpg
right view: http://img502.imageshack.us/img502/8...ghtviewwq4.jpg
thanks in advance!
thanks in advance!
RE: transmission help
oh man I just looked at the motor pic's...it's a freakin rice popper stang!!!! ya' might want to post in the 2.3 section...Mine used to be a 2.3 before I wised up and put a 5.0 in it
ORIGINAL: mjr46
Man sounds like ya' bought a real west baginia ride!!!! hope ya' didn't pay to much cause looks like ya' gots lots a work ahead of ya'
ORIGINAL: mjr46
ORIGINAL: mjr46
if it's a stick shift car then the trans fluid fill is on the side of the tranny case on the right hand side it has a square port for a rachet to fit in it.
Well it is a 2.3 not a 5.0 and the "mystery stick" as you labled it in your picture is the one for the transmission fluid level. You want to check it with the car warmed up and running. It is also where you add the fluid, get your self a good funnel. Carefull you don't over fill it, to be safe if it shows about half full it should only take half a quart.
ORIGINAL: raven_ghostwolf
thank you a lot, though -- i really appreciate it. my car was starting to act funny and i believe it was due to lack of transmission fluid [since everything else was fine], so hopefully this'll do the trick.
i will possibly give an update tomorrow.
as of today: i put in the transmission where raven_ghostwolf suggested, and all is well now. runs more smoothly, and doesn't do the "jackrabbit" thing (where the car lunges forward and burns my tires) anymore.
so, thanks again.
so, thanks again.
