please help new stang owner
Old 03-26-2003, 11:28 AM
jamesb5
jamesb5's Avatar
Default please help new stang owner
i just bought my first stang, a 95 gt, when i first start it, it will idle at about 600-800, then if i rev it at an idle it will drop to about 400- or 500 and sound like it wants to stall, it also hesitates while driving, i had it checked out on a computer, it showed that the o2sensors were to low, but the mechanic said i had a vacuum leak, i took the advice of everyone on this page and replaced all of the rubber boots on the vacuum lines, and sealed them with silicon, still does it, i changed the plugs and wires yesterday, and it still does it, im really stumped here, could it be the o2sensors? if it is i can get them cheap, but do you need a special tool to get them off?
jamesb5 is offline
Old 03-26-2003, 02:59 PM
jamesb5
jamesb5's Avatar
i changed the fuel filter to, right now im putting all new plug ends on the vacuum lines, and i cleaned the throttle body, still starvin for fuel
jamesb5 is offline
Old 03-26-2003, 04:32 PM
91GT5.0
91GT5.0's Avatar
Wouldn't hurt to change the O2 sensors, though I don't think that's your problem. Check to make sure all the grounds are connected. Check fuel pressure with a gauge. Check IAC (on throttle body).
91GT5.0 is offline
Old 03-27-2003, 05:49 PM
DrifterX
DrifterX's Avatar
Clean your MAF. Take it apart, clean the points with alcohol. Make sure not to get anything wet thats not supposed to be.
Peace
DrifterX is offline
Old 03-27-2003, 05:59 PM
jamesb5
jamesb5's Avatar
cleaned the maf before, bought new air filter, but havnt check iac, where is it located exactly
jamesb5 is offline
Old 03-27-2003, 06:39 PM
91GT5.0
91GT5.0's Avatar
The little cylinder shaped thing on the throttle body, has a clip with a wire attached to the end
91GT5.0 is offline
Old 03-28-2003, 04:00 PM
jamesb5
jamesb5's Avatar
if it is tha iac do i have to have it replaced? or clean it, or what
jamesb5 is offline
Old 03-28-2003, 04:29 PM
91GT5.0
91GT5.0's Avatar
take it off, seperate the 2 halves spray some carb/brake cleaner in all the orfices (:P), let it dry, put back together
91GT5.0 is offline
Old 03-28-2003, 05:18 PM
jamesb5
jamesb5's Avatar
throttle body cleaner work?
jamesb5 is offline
Old 03-28-2003, 06:34 PM
91GT5.0
91GT5.0's Avatar
Yeah, same thing as carb cleaner
91GT5.0 is offline
Quick Reply: please help new stang owner
