CLUTCH
Old 09-07-2007, 08:50 PM
93five0
93five0's Avatar
Default CLUTCH
Will Installing a cheap clutch make me lose hp....
93five0 is offline
Old 09-07-2007, 09:13 PM
1991LX5.0
1991LX5.0's Avatar
Default RE: CLUTCH
you wont loose HP but when it starts slipping it will definitley slow the car down. What clutch are you looking at? Id rather do it right the first time then have to drop the trans and everything to do the same thing twice
1991LX5.0 is offline
Old 09-07-2007, 09:17 PM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: CLUTCH
Just by a SPEC.
WhiteWindsor is offline
Old 09-07-2007, 09:23 PM
93five0
93five0's Avatar
Default RE: CLUTCH
I used to have zoom NNC F348 now downgrading to the napa NNC MU481 do you think i will be able to tell the diff....?
93five0 is offline
Old 09-07-2007, 10:43 PM
cleanfitty
cleanfitty's Avatar
Default RE: CLUTCH
ORIGINAL: 93five0
I think the napa clutches are made by Perfection, and I believe Perfection also makes Zoom...
I don't think any clutch has an effect on horsepower..
cleanfitty is offline
Old 09-08-2007, 01:41 AM
gspfunk
gspfunk's Avatar
Default RE: CLUTCH
The clutch won't technically affect HP, but you need the right clutch for your power level or it will slip and wear out faster. The pressure plate also needs to be able to clamp w/ the right amount of force or you'll have the same issues. Do it right and match your parts up correctly.
gspfunk is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: CLUTCH
