got caught in storm now car running bad
Old 09-09-2007, 10:39 AM
grabbem88
grabbem88's Avatar
Default got caught in storm now car running bad
i got caught in a bad storm and had to pull over for a while,but when i started it back up the car acted like i blew a head gasket...it cleared up,but now the car cuts out until the car has run for awhile. i scraped and clean the cap and rotor..do i need to look elsewhere?...i have idea's but i want to see who else has expeirenced this,and what they came across
grabbem88 is offline
Old 09-09-2007, 11:08 AM
aode08
aode08's Avatar
Default RE: got caught in storm now car running bad
get a long extension cord and mom's hair dryer or sis's and hit the alternator and remove the cap and wirning harness for the dizzy and hit it to.
Replace the rubber boot for your dizzy if its missing and leave your hood open to dry.Pack die electric grease on the dizzy/ alternator harness and ignition coil harness and plug em all in.
aode08 is offline
Old 09-09-2007, 11:16 AM
grabbem88
grabbem88's Avatar
it was bone dry that night thanks to those long tube headers...i heard of spraying some wd-40 inside the dizzy.
Old 09-09-2007, 11:19 AM
aode08
aode08's Avatar
that helps, also check your salt and pepper connectors and pack them with grease.
I have the boot on my dizzy and packed all harnesses, rain has never done this to me, and I have more openings than you do.
aode08 is offline
Old 09-09-2007, 11:26 AM
grabbem88
grabbem88's Avatar
openings?....no my driverside fender has no splash gaurd......semi's blasted me pretty bad that night
Old 09-09-2007, 11:33 AM
aode08
aode08's Avatar
i have no driver's or passenger's side lol, I bet it got all over on the dizzy
aode08 is offline
Old 09-09-2007, 11:43 AM
Maxwelhse
Maxwelhse's Avatar
ORIGINAL: grabbem88
You problem sounds exactly like what happens to late model GMs when they have a cracked coil pack... Is your coil still over there without a splash guard?
Maxwelhse is offline
grabbem88
grabbem88's Avatar
so why is it taking some run time till it clears up...
Old 09-09-2007, 11:50 AM
grabbem88
grabbem88's Avatar
ORIGINAL: Maxwelhse
ORIGINAL: grabbem88
yepper....this is what i was thinking too...but the last time this happened i had no top end at all 4500 is all it had....how can i test it? spray water on it while running car?
Old 09-09-2007, 12:17 PM
Maxwelhse
Maxwelhse's Avatar
I'd wait until tonight and go out there with a spray bottle and put a mist over it. You might be able to see some cross-arcing to the chassy. You can also measure the resistance of the coil to see if its out of spec. A visual inspection for signs of leaking might be good too.
With that said, I had a GM that passed both tests but still had a very small crack in the coil... It took 6 months before it got bad enough for me to see it. I hate to recommend that you just change parts, but... coils are cheap.
Quick Reply: got caught in storm now car running bad
