The best HCI combo for under $1800 ?
Old 09-11-2007, 09:59 PM
LS1this
LS1this's Avatar
Default RE: The best HCI combo for under $1800 ?
for the $ this thumper package seems like pretty good deal
http://www.thumperoforangepark.com/
LS1this is offline
Old 09-12-2007, 06:41 AM
tooslow5.0
tooslow5.0's Avatar
hey ls1, awsome link. that seems like a great deal if he does good work. would it be worth the 175 having him add gt40 valves?
tooslow5.0 is offline
Old 09-12-2007, 10:07 AM
drhoward
Penis Mod Erator
drhoward's Avatar
I got thumper to port my gt40p heads, he does an awsome job. I am not sure about his packages but his porting work is first rate and he is a really good guy to deal with
drhoward is offline
Old 09-12-2007, 05:07 PM
vtecwho
vtecwho's Avatar
my hci is not "the best" but it gave me the hp in my sig. its a VERY basic set up and im very happy with it. i know of a guy that has edelbrock performer heads and a tfs II cam and he only makes 271 tuned....but runs 12.7s.
for what i have, i dont think it would even cost you a grand. gt40 heads unported have a little lower compression so take that 800 left over and save for a sc and boost it to 5lbs!
vtecwho is offline
Old 09-12-2007, 10:17 PM
LS1this
LS1this's Avatar
ORIGINAL: tooslow5.0
good Q, I was wondering that also, my guess is if you were going to run a bigger cam than he recommends with the package or were planning to go forced induction down the road it might be worth it.
LS1this is offline
Old 09-13-2007, 12:11 AM
Mustangkiler
Mustangkiler's Avatar
If you get a supercharger you wont be running 5lbs for long.
Mustangkiler is offline
Old 09-13-2007, 01:57 AM
KovacMotorsports
KovacMotorsports's Avatar
In my opinion a good budget H/C/I setup would be Thumper ported GT40p's with SS valves and a Crane rocker arm stud conversion, Scorpion roller rockers, TFS stage 1 cam, and a good used intake ( i.e. Eddy, Trick flow, Holley, etc.) or a new Typhoon.
KovacMotorsports is offline
Old 09-13-2007, 07:24 AM
tooslow5.0
tooslow5.0's Avatar
wow, alot of good info on this thread- thanks guys! is it possible to mill the gt40 heads to regain some compression? or does it screw up the port and bolt alignment for the intake?
Old 09-13-2007, 07:58 AM
ZachW04Stang
ZachW04Stang's Avatar
gt40ps, comp xe270-14 cam, and trickflow intake. I make power from 1800-5900 rpm and cost is very cheap. Around $1000, cheaper if you get the intake and cam used.
ZachW04Stang is offline
Old 09-13-2007, 08:26 AM
QatarStang
QatarStang's Avatar
Nice vid iceman, you destroyed that 'maro on the launch and whooped his *** up top.
QatarStang is offline
Quick Reply: The best HCI combo for under $1800 ?
