solenoid clicks an car doesn't start
Old 09-17-2007, 12:49 PM
Jfsram
Jfsram's Avatar
Default RE: solenoid clicks an car doesn't start
ORIGINAL: ahittz24
No I just told you what to do. Listen, Your solenoid is a relay if its clicking that means its making contact. Which means your ign switch and wire is probably (99% chance) perfect. Its sending voltage to the starter but there is no ground to complete the circuit. Run a ground from the ps/ac bracket bolt to the fenderwell. Then try it.Use at least a 4 ga wire. Try that and let me know what happens.
Just because a relay clicks does NOT means it's working.
The job of a relay is to take the high current and close the path across the 2 big lugs.
The relay is obviously getting energized and closing the contacts but the contacts could still be bad and not sending current through.
Jumping the 2 big lugs will confirm that.
Jfsram is offline
Old 09-17-2007, 01:21 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Jfsram
or it will melt something if he installed it wrong
AdderMk2 is offline
Old 09-17-2007, 01:26 PM
tmajikman
tmajikman's Avatar
ORIGINAL: AdderMk2
ORIGINAL: Jfsram
Very valid point right there.
tmajikman is offline
Old 09-19-2007, 01:08 PM
hatchdemon89
hatchdemon89's Avatar
well turns out i had the wire backwards i forgot silver notch or whatever he was right movin on the charging problems now lol
hatchdemon89 is offline
msavoia23
12
07-07-2018 12:08 PM
fdnyems19
08-13-2015 09:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: solenoid clicks an car doesn't start
