sn95 brake + 5 lug
sn95 brake + 5 lug
hey guys, i finally found me a nice brake donor. its a 94 or 95 red 3.8L mustang sitting in a junkyard.
i was able to rip out both calipers along with the rubber brake lines. the rotors im not taking because they are rusted out and id like new slotted and/or drilled ones. as far as the hubs and spindles go, i ran out of time because the junkyard was closing. any tips on removing these or any other part i should take next time i go? thanks
RE: sn95 brake + 5 lug
ORIGINAL: primetime5.0
a pickle fork and a large hammer for sure, I would just ditch the brake lines and get MM SS lines
ORIGINAL: stang8689
Don't use the rear cause its 7.5, find a 94-95 GT rear
ya you can use the fitting but in the end there just stock rubber lines, just upgrade now while you have it apart and get the SS lines that dont need any adapters, I believe you can use the stuff from the 7.5 just not the housing itself
what about the rear axles? im about to head to the junkyard for the rest of the stuff. will 7.5 axles work in my 8.8? i know the sn95 axles are a bit wider but i dont mind if they stick out a tad bit more, just wondering about it actually working
all of the brake parts, and axles from the 7.5 will fit in your 8.8 i got my stuff from a 96 v6. if you order wheels for an 05 mustang for the back the wheels will not stick out. you will just need to take off your quad shocks.
i have wheels for a 94-04 up front and for an 05-up out back and they dont stick out
[IMG]local://upfiles/59932/37539466FD2C4437AE9C617F208C7F80.jpg[/IMG]
[IMG]local://upfiles/59932/0AFAF904F1E449CBB3C008AD2FF7C901.jpg[/IMG]
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
